evening all I’ve just set a waypoint from the maps (first time trying waypoints’)i didn’t fly it first. Just from maps all looking good then i just couldn’t press the start for fear of not doing it right . should i just trust the mini 4 tia from a scared owner
Just make sure you know where the pause button is - start the mission and keep a close eye on the drone - if anything starts to go wrong hit the pause button - you’ll then have some time to think and cancel the mission if necessary
thanks for that
For way point missions, make sure you can see the start point and every other way point - might be an idea to have the camera say start recording/stop recording m/zoom etc along the way as you’ll be able to follow its path easier. They’re dead easy to cancel mid-mission too! Go for it - then try waypoint for a dolly zoom subject…that’s very cool
Set the missions to max height in an area you know well and hit the start button. I also tick the complete the mission on loss of signal, but it’s no big deal if you dont.
Start off small, with a couple of points set if you’re too worried. They are easy once you get into them, and you can always do a mission on the fly (sorry pun intended) for you to repeat at a later date.
You can use Litchi to plan the mission but it’d not straight forward
Thank for that mate i will give it a go when the weather improves
Thanjs mate for the info
