I was just testing and tried the circle quickshot, simple to use but when it got to a certain point it went out of control and heading for the trees.
Could this be wind catching the blades, I had no wind warnings or the gimbal settings to low to mange to turn camera in time.
No idea but you could try using:
https://airdata.com/features#tab-panel-2
Please post the results if you do.
I finally got it working it was trail and error.
the reason Quickshots new to me is I always kept my Mavic pro on 0700 with NLD so at the time it was a decision I took no rules no updates over Quickshots from DJI.
After playing around yesterday with all the settings as suggested here, I had great fun.
Another thing handy is when told low battery RTH that there is enough battery life with the mini to transfer 7gb + of footage to you phone if needed.
Did you find out what happened when it zoomed off?
I’ve been playing with QS and found it pretty good.
Sometimes it does lose its target - but then it should just stop in position.
So a bit disconcerting to see if veer off like that.
I used one POI and done about 10 different distances and heights, found highlighting the centre point much larger, I only had loss of target when it was drifting behide a few trees for few seconds.
