Working my way up on the drone building world… lol
First there was the Meteor 75 frame swap, then the Crux 3 canopy and antenna upgrades, now working on a bit more challenging operation, the conversion of a Mobula 7 HD into a Toothpick!
Whilst browsing UnmannedTech’s bargain bin I saw one which was missing a motor and other possible problems and had the idea of converting that into a Toothpick with a HD DVR (Caddx Turtle v2).
Fast forward some days, I now have almost everything I need for the build, missing the motors, but have decided to start putting things together. I browsed thingigverse for a suitable canopy and once I found one, had the help of @Njoro to print it out along with some other required parts.
I received the prints today by mail and was eager to see how everything looks on the frame It’s not all on the frame yet, but at least now I have a better idea of how things might/should work all together. It also has given me a chance to identify a major pain, which is the diamond vtx that came on the drone, this thing is really getting in the way of the build, so I might need to discard it for a smaller solution (might do a swap with the Meteor75 vtx , but not sure yet).
- Actually the big challenge on this build is the fact that the caddx turtle dvr board is a 20x20 mount, hence the height of the stack* (its fram - fc - adapter plate - dvr - vtx* - canopy) *ideally it should be a small one which I can just chuck inside the canopy
I have not added the FC on the stack bc as it is now it doesn’t fit. The power cable is soldered right next to the USB plug on the bottom side, and this is keeping it from fitting on the frame (its a crux3 fram). But the overall hight should not change with it added, since I left the FC gummies on the stack as a place holder…
Well, enough chat… here is what it looks so far:
The red bits in the middle of the stack, plus the white canopy and battery plate, are the goodies @Njoro printed out for me (
) I added the picture with the battery pad just so that he could see how it looks on the frame (fitted like a glove btw).
Motors are coming from China, who knows when that will arrive. I got some dirt cheap 1104 4300kv, same as the BabyApes, and initially I’ll run it on 2s. I will most likely settle on the gf3018 bi-blades, but will try out the 3016 tri-blades, and a 25xx tri-blade as well… The esc on this board is only 5a, so I’ll have to be very cautious setting up.
Until the motors arrive I have some solder work to do as well; de-solder battery lead, the motor plugs, and the led. Will add an elrs rx and a battery lead with a cap on… Also, since I’ll be flying this on 2s at first, I’ll put together a couple of adapters from bt2.0 to xt30 and gnb27 to xt30, this way I don’t need to buy more batteries or charger for the time being… lol times require me to be cheap…
That’s it for now, just wanted to share the experience with you all…
