Hi all,
Does any of you know if we can modify the power level options from the VTX?
Reason I’m asking it is bc I want to enable the low-power-disarm function, which will set the vtx to its lowest power when disarmed, but the problem is that the vtx in question has a power level of 0 as its lowest setting, so when I enable it, I pretty much lose all signal, and that is not very convenient. So I was wondering if I could modify the power level structure, to either delete the option or maybe change the actual power level.
