Hi all my quad when I enable the beeper it beeps once or twice then stops. After that it will not re arm again and i have to remove battery and plug back in again. I have flashed betaflight and esc’s tried different switch on my reciever but cant get it to correct itself. I have another quad with same specs so decided to copy over the settings but no luck.
What buzzer are you using?
Fancy sharing a photo of the connection?
not an actual buzzer the motor buzzer. when i enable it with a switch it wont let me re arm when i switch it off.
i am not in need of assistrance now i found a beeper in my bag and works fine now thanks for the quick reply steve
