Something is happening…
ordered Inspire 2 Titan Inspire 2 TX Mount…
Your fault
@PingSpike
Your fault
@PingSpike
Hope you used our GADC #members-only Titan discount code!
What…![]()
Oh!, FFS !, you have’nt !, you have !.
Always check the GADC Members area before you part with your hard earned !
Could you cancel order and re order using code?
I’ve dealt with Titan a lot, they’ll probably be happy to add the discount on if you explain the situation.
It has expired Chris but if you click the link below there are plenty of sellers with it.
It’s glossy 5D.
https://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_nkw=5+Diagonal+Carbon+Fibre+Vinyl&_sop=15
Thanks Richard
Shipped already, I’ll let it go…![]()
Power to both amps all wired in now ![]()
Along with the aircraft-style power switch and battery meter, soz, crap photo buy you’ll get the idea:
Just need to wire the RF side of things next, then final assembly ![]()
Looking good.
Does your battery have a built in protection circuit?
This is all I could find mate:
12V A grade PCM, over-charge/discharge protection, over-heat protection
It’s the same battery that was fitted inside my original Titan Atlas, I’ve not changed it, simply relocated it ![]()
In that case it seems it does.
Should cut off on low voltage.
Looking good so far Rich.
When are you available to come wire my van?
I don’t know when I’m going to find the time for that
Final pieces of the jigsaw…
Tripod (details over here), laptop plate/shelf and some 50mm wide Velcro (branded, as I was unsure of the stickiness of the unbranded stuff).
The laptop plate came with a sheet of foam and a weird elastic band thing
The tripod mount for it came with a 3/8" - 1/4" reducer fitted (it just unscrews).
And it was the perfect size for my case too
This caught me out though…
The feet on the case stand taller than the velcro
I did contemplate taking a stanley to the feet and trying to cut them off… But in the end I simply doubled-up on the velcro, problem solved.
The end result…
Should give an acceptable connection to the end of the garden.
I’ve just ordered some bigger 7dBi gain whips for it too Dave, which will definitely help cover the distance
Whips … so that you can give the Inspire a thrashing if it misbehaves.
