The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 15/09/2020. It remains the responsibility of any pilot to check for any changes before flying at the same location.
Thank you @Petenlancs for adding this location to the DroneScene map
yes good spot , can be busy but I found a few places that be good to TOIL from if early / quite and a few spots just back from the path on the main reservoir ( Greenbooth ) and the other end at the top of Naden Middle. I have also TOIILed further up on the moor as well make sure you have a good landing pad to keep the tough moorland grass down
I’ve flown here too @Petenlancs
I’ve just added a new Parking marker to this location @Petenlancs
