Is this ok to fly or are the props to close and is the receiver ok on the arm
looks ok to me, its a little closer than I’d prefer but shouldn’t have any adverse effects.
the RX antenna on the arm is fine also but just keep in mind if you bend a prop it could cut it.
I tend to snap my props more then bend then tho I am going to move the RX antenna to just under the arm
