The obelisk at Wentworth Woodhouse, also known as 'the Needle's Eye', was built between 1722 and 1728 by Thomas Watson-Wentworth. It is a slim arch structure that was originally called 'Obelisk in Lee Wood'. The obelisk is one of the earliest ornamental structures in the park and is thought to resemble the eye of a needle. It stands alone in a tranquil corner of the park, adding to the estate's picturesque landscape. I parked on Street Lane and followed the footpath to the structure TOAL from the footpath
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 10/06/2024. It remains the responsibility of any pilot to check for any changes before flying at the same location.
Hi @TheBinman. Nothing to it, really. Just park up either where I marked or in the parking area at the end of Street Lane. Then take the footpath at the side of the house that is there, and Bob’s your uncle, you arrive at another gate that allows you to walk around it if you would like a closer look. Although it’s a footpath, I was there for about an hour and never saw a single person. I’m guessing depending on when you go, it could be busy at times.
I’ll probably visit either early morning or late evening, to minimise the chance of clashing with other visitors, then I’ll be able fly the Avata 2 in peace, without having to worry about upsetting anyone.
For 12 years, I worked only a 5 minute drive from that location and I never knew it was there.
Flew here the other day. The monument is very unusual and has a rather interesting story surrounding its construction. It is claimed that Needles Eye was built to fulfil a bet.
Thomas Watson-Wentworth was apparently boasting to a friend about how skilled he was at driving a carriage and claimed that he was that good he could ‘drive a coach and horses through an eye of a needle’. The friend took him up on the wager and Thomas had Needles Eye built to prove that he could do just that!
