Neo 2 and flying options
I’m convinced I’m missing something bl££ding obvious but here goes..
I have a Neo 2 and RC-N3 controller. All system updates are done
If I fly the Neo with the phone there are loads and loads of different flight options. But when using the controller and pressing ‘quick shots’ there are only about 5 visible options ? There must be some way of getting all the different possibilities to show up via the controller!
Hi @Eggzy , I have the Neo 2 & RC-N3 controller, and while sadly I am at work and it is at home, I am sure there are only the 5 that are below:
Are you able to upload a screenshot of what you see on your phone?
You’re right
They are the five I have
I just thought there might be a way of getting all the other options if you fly by phone only.
Obviously that must be it
But thank you for taking the time to reply :ok_hand:
I know it is possible that when flying by phone only you don’t get to see all 5 as some are hidden. You would need to go into the settings and mark all (or just those you want) as a favourite. From memory there are some slightly altered ones, but when I tried them I didn’t find them any good, so left it as the default ones.
