looking amazing and Mads seems to love it too ![]()
Lots of bling - but screen not made bigger ?
it is just soooo disturbing that they ALL dropped their youtube reviews of the TX at the same time. Classic NDA!
I think this is perfect ‘for my use case’ (ie - only doing FPV) - I want a small radio with good size gimbals and a Nomad integrated. I only use the screen for config and bigger screen means bigger radio.
I love the Boxer but it is a bit big for no obvious reasons - lack a few buttons and the antenna is a bit of a pain. I was considering the Nomad module to go with my 10 inch DBR-4 but I think I will switch to that one if there is no drama coming out from the early adopters.
Damn - may not be the best layout for ‘pinchers’ - mind you the guys hands look massive compare to mine ![]()
Hmm, kinda hard to say.
The replaceable end panels that he seems to struggle with look kinda like the layout of the Zorro.
I’m a hybrid pincher and fly the Zorro as my daily driver - but I also use a neck strap so I’m not trying to support the radio in quite the same way.
I’m a pincher, and I was initially worried that my big hands might accidentally hit the back switches. However, after using it, it seems to be fine for me. I can see how others might knock them depending on how they grip it. The radio is wicked though!
Is it that much smaller than the Boxer?
there are size comparison in Oscar’s review - Review: Radiomaster GX12 - A Compact Radio That Can Do It All (But with Compromises) - Oscar Liang
A ‘bit’ smaller but with folding antenna/gimbals making it a handier package to travel with - and it also has the dual band Gemini integrated - and a few more extra switches… I will likely order mine this month (waiting for some XR4 receivers - the new Radiomaster dual band Gemini ones
Quick question - can you replace the stick ends (I prefer rubber ones instead of the default metal ones)?
