I know this somewhat repeats other threads, but for my sanity I’m trying to keep my ramblings on this topic in one place:
I am looking to get a handheld camera to supplement my drone footage and am really having a headache choosing.
Use case:
- Handheld footage exploring locations to cut with drone footage
- Vlogs for my next job which will be a mix of me standing in one spot (using a tripod) and some of me walking on location while talking to the viewer.
- ‘mild’ action, i.e. setting up the camera in an area where people will be working over a period of time, or me and other subjects while doing activities.
Consideration:
- I am strongly leaning towards a 360 camera as this will mean when I am vlogging or even when capturing people at work, I don’t need to focus on framing. Also means I can set the camera up in one place on a tripod and capture everything going on around the camera. It can also capture super wide angle scenes.
- Therefore, my leading contender right now is the “insta360 1 inch 360 edition” as it appears to be the ONLY 360 camera that has even half decent quality. The downside being that it isn’t waterproof.
***Advice here needed on camera choice - would this work? Should I be seriously considering something else? I did also consider the DJI Pocket with it’s active track ability and far superior quality.
Technical questions:
- Obviously 360 footage made ‘flat’ isn’t going to be 4K. More like 2k I believe?
- The Insta360 I believe also only records at 24fps at the highest resolution, or 30fps at a slightly reduced resolution.
****Can I record on my drone at 4K 60fps or 4K 48fps and easily mix with footage shot at a lower FPS? I figure that keeping the source footage at multiples of each other would probably help. Presumably the resolution isn’t an issue and it will simply downscale the 4K drone footage to match the other cameras output footage?
Microphone:
- I would like the DJI wireless mic.
- But the bracket that comes with the above mentioned camera appears to only natively support the Rode wireless mic (physical fitment).
*Are the Rode Go mics any good? Otherwise how difficult would it be to record the audio off camera and align it in post if I can’t attach a DJI mic to the camera?
***** If I plug the mic in to the camera, am I limited to the bitrate that the camera natively records at?
