Not flown my MA in 18 months..... what extra pre-flight checks?
Hi all
I haven’t used my MA for ages and was wondering if there might be any issues (battery related in particular) that I might encounter???
Also, any firmware updates?
Ben quite at least a couple of firmware updates in the past 18mths. Be sure to update all the batteries as well as I’m sure at least one of the updates was battery based.
As to the batteries - give them a thorough visual check for any swelling, cracking or other deformities and if at all unsure then don’t use or recharge them.
Having drowned an Inspire after assuming a long-disused battery would hold a charge I’d suggest that you spend some time flying the MA at low altitudes close to you and keep a check on battery behaviour. Mine failed after a quick high-speed burst, unfortunately and stupidly over the sea. Basically give the battery a bit of a hammering somewhere safe and be prepared to land immediately if it shows abnormal behaviour.
Once you have checked that each one behaves itself - enjoy!
