O2 and canary wharf
Second attempt at video, seems too fast so still lots more practice needed
Yes to fast but good content try a side panning shot instead of a rotation, much more dramatic. Pick you start point then go a bit to the right, start to pan left until you get past the stop point, you may have to break it down into two or three takes… Ta
thanks, completely new to video and a whole new set of skills to be mastered. Thanks for the pointers
ok as your first ever flight, as you have realised yourself practice makes for better video. You may be better practicing somewhere else as its such a built up area there with lots of flight restrictions. Better off in countryside so you can get used to controlling it smoother.
Also make sure your in cinematic mode rather than normal, also the controls are position sensitive so just try very delicate small movements on the sticks and you will get much smoother footage.
Is it a mini2 your using?
Andy
mini 3 pro
Oh nice, well deffo fly and get practice in open countryside
Slow it down in post. If you haven’t got any editing software download Divinci Resolve its free and it will do what ever you want
I did have a look at davinci resolve but it seems very hard to use. Guess I will have to try some you tube tutorials. Thanks for the advise
It seems daunting at first but there are some very good you tube videos on it start with basics then type in reduce speed once your going it’s easy. You can also do speed ramp which is sparring fast then slowing down or vice verse. It’s worth it in the end. If you can find the right videos get in touch again good luck Tony
My first night flight around the Isle of Dogs area…
Many thanks to @grandad1950 for swiftly replying to me on the day regarding the DJI authorisation unlock code process with was painless and very quick to do.
