Hi All
I’m hoping to get the advice of the more experienced members for how to optimise the settings within the UAV Forecast app to make sure that flight opportunities aren’t missed.
I’m frequently getting the “Not Good To Fly” notification within the App and would appreciate any advice for the thresholds of the settings. In no way am I wanting to reduce anything to get around this app’s advice, if that were the case I may as well not use it, however I’m wondering if I’ve set the parameters too conservatively.
The stats that show up in some form of red the most are the wind and wind gusts, both set to display the speed at 400ft with the limit at 22mph. Wind direction and Sats locked are the others that most frequently show red. I assume that the direction is linked to the speeds but the stats locked is set to a minimum of 12 but I’ve no clue if this is too high or even how many are the minimum required.
Any help would be appreciated
