does anyone know of any programs or apps you can use to mod the flight parameters and settings in order to bypass the factory set limitations such as altitude, speed cap, etc..? i found a “modded” version of the PotensicPro app that claims sucu things are modded, but after testing, it appears the modder is amateur and only managed to change the setting readouts of what numbers are displayed in the app and not the actual parameters (i.e. the number that is now shown when set to maximum allowed is “10,000” instead of the 2650 that it actually is).
i have decompiled the .apk file and searched through a lot of the code for where i can change this, but have only been able to find this readout data myself. any help?
