Only 2 small car parks but close to a local train station. The nearby airfield is far enough away not to cause an issue if you stay away from it. Doesn't tend to get very busy especially in the evenings. Good views over towards Lincolnshire.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 25/06/2020. It remains the responsibility of any pilot to check for any changes before flying at the same location.
Thanks for adding to the DroneScene map, @MrG.
Thank you for sharing this, is only 25 minutes away from my and I never would’ve know if not for this post!
Went there earlier today with my 2 year old and it’s a great site if you want a few nice shots and some large open space without many bystanders.
Attached one of the photos I managed to get by the main sculpture in the park.
You’re very welcome. Just keep below the max height so you don’t run into any light aircraft from the airfield. Only other thing you’ll see is a few cyclist and the occasional horse rider which you should of course stay well away from too.
