Another learning curve lol,finally got a flight in after all this bad weather, getting a bit of confidence now, although I didn’t realise how close to the tower I was when I clicked rth
Love the clip, you’re brave with the VLOS
great colours surrounding the tower
The only time I lost sight was as it went round the tower, if you check I ascended so I could see it again
You may want to check your gimbal calibration.
Facing in both directions objects (tower/horizon) appear to be slightly rotated to the right.
I normally do a calibration before every flight but was so eager to get out in the sun I didn’t bother
that’ll teach me
You do a gimbal calibration (not compass calibration) before every flight? You’re probably the only person that does.
Yes a gimbal calibration lol just something I heard along the grapevine that it doesn’t hurt to be over cautious
I’ve done one in two years … when I replaced the gimbal.
On the Mavic, there’s a wheel on the controller that allows for in-flight horizon adjustment … easily caught by accident (I discovered in the early days). If there is on the P4, you may have done the same … and this adjustment is not removed by a gimbal recalibration … IIRC.
Hold C1 and right thumbwheel turn should adjust it in flight (I’m sure it’s same as Mavic)
Ah sorry my bad, looked like you took of and landed in that dense forest and flew to the tower.
Lmao I was on the edge of it in a little clearing to take off then walked 50yds to edge of road never losing sight of drone buddy, not worth it with some of the peeps from the chase, proper jobs worths
Cheers buddy I’ll try that next flight
Just tried C2 and right dial and definitely alters it, I’ll have a play in flight next time, thanks lads another thing I’ve learned
Looking at that pic do I need to pitch the gimbal to the right or the left, I’ve got a mental blockage, I call it one of my blonde moments even though I’m bald
see through hair pmsl
To the right (clockwise). You need your image to rotate anti-clockwise relative to the sensor.
Cheers Dave
Wow - how far was it to the Tower. I am amazed but glad that you didn’t get any interference from all the tower bits and bobs. Good clip thanks.
About 1/2 a mile, i could just see the P4 as a black dot lol need a strobe for it
@Matty1
Wow… 3:05 was bloody close, you lucky devil.
Steve
