Anyone come across any QMA connector dust caps? @njoro maybe?
Looking at my case, the permanently-exposed connectors may suffer long term.
One possibility is to make some using just a bit of heat shrink moulded over the top of an unused connector?
If you let me know the dimensions I can print you some
@njoro said try this…
https://www.amazon.co.uk/dp/B00OK9C7O4/ref=cm_sw_r_cp_awdb_t1_8kiRDb440Y159
A little mod and jobs a good one…
Thanks James, may take you up on that if I can’t find a rubber boot solution.
Do these fit, they look too big?
I don’t know really, it’s one of those things that you buy and try and should they be slightly smaller they will stretch making a tight fit.
Heat shrink will mold perfectly for that and as you know I have the same connectors on my antenna so I could ran a test print and let you know as I’m in the process of designing and printing a camera hood for the X5S 45 mm lens.
These would look great on the case but cant find any in UK.
I’ve used Sugru to make caps for things like that.
I went the zero cost route in the end:
I had this coupler connector which I sacrificed this evening.
These connectors latch on, so can’t fall off in transit
Just seen this, it’s a good idea, knowing me I’d lose one.
You could always join them together with a bit of wire.
Like those mittens that had a bit of string running up one arm and down the other
That would be a long piece of wire ……
Then instead of losing one he will lose both
NOT if you thread it up one arm ……
I’ve got lots of single socks, do you think a string is a good idea and would it be under the underpants or outside the underpants…
