Aerobatic rc model with smoke system , in the prop hang filmed from above with the mavic 2 pro at our flying field earlier this year , music comes from epidemic sounds
Thanks all
Cool !
Is it an ic engined plane injecting oil into the exhaust ?
HI yes its is a 55cc petrol engine with a smoke pump that pumps smoke oil around the exhaust before pumping the warmed fluid through a spray nipple on the side of the outlet , it does make the model a bit messy though
I bet it does - in the distant past I remember wiping off unburnt castor oil from the exhaust of glowplug motors - smelly and messy ![]()
Fortunately these are not quite as bad lol, worth the mess for the results though
