@ziceman mark
I’ve noticed he comes on every night - ish for literally about 2 mins & go’s offline, from what I gather he’s not reading his messages for whatever reason, just saying mate.
Thanks Richard for confirming what I was thinking as well, I had a glimmer of hope as I read on another post Chris had a conversation with him.
Was meant to add that above,
Was also meant to say I’ve only kept an eye open ( in the hope ) that he was still about ( but hopefully not ) I need him anytime soon as was a handy connection for those who need it,
I don’t think that was recently I maybe wrong but I’m quite positive not as I spoke to Chris last night & we was having this discussion.
Yea same link thanks.
It was this post I read that gave me hope.
Yes I see that post,
When I was chatting to Chris last night as he’s not been on the forum as much recent, I said to him good luck in the hope in getting a reply etc etc, I think he was unaware of the chats in this thread recently of no one being able to get hold of him, maybe he’ll be one of the lucky ones & get a reply. ![]()
He hasn’t even seen my message, let alone replied ![]()
Thanks for the confirmation as I thought it was only me banging my head against a brick wall ![]()
Good morning everyone I’m new to the forum, I would like to buy the patch for mini 4 pro, unfortunately I’m not able to make the payment in bit coin, Is there an alternative to payment? Thank you.
He always took PayPal.
Not sure if he is still around however
Yes, same for me too.
He hasn’t posted anything on his Telegram channel since January, but he was last seen this morning.
I wish he was around as I managed to do my old mini 3 pro by your guide Chris
I have another mini 3 pro and mini 4 pro and like to mod via sincoder but no answer ATM.
I’m wonder if something happened to him as you notice it similar time most of the time where it be 00.06 now it’s 01.06 coincide with clocks going forward so is it the app ghost login.
https://www.dji-fcc.com/djifcc.zip not working anymore. What happened with the chinese?
This one is
Hi,
I have the hack from sincoder and it works amazling well (mini 4 pro, rc2). I was wondering if anywone has upgraded to the newly released firmware (v02.02.0000) and if the hack perists!
Cheers!
DJI RC 1 01.03.1400
The initial FCC installation is not available. Available for RC with firmware 01.03.1200 or lower.
If the hack is already installed and firmware 01.03.0400 or higher, you can update RC and run djifcc.exe again.
If the firmware is 01.03.0100 or lower, be sure to install the hack again before updating!
Additional functionality. Dangerous! do not use if you do not know what it is.
After have patched your DJI RC / RC pro, go to DRONE NAME in INFORMATION
Tab than delete the drone’s name and type:
disable - turn off all hacks
enable - turn on all hacks
reset - reset to default config
500 on/off - force max height to 500m or not. (Not altitude hacking! Remains 500. Only for India users)
force_fcc on/off - enable/disable force fcc (drone will ignore country code setting)
rcgps on/off - enable rc gps or not (can not set RTH point to RC location after turn off)
led on/off - turn on/off drone led
atti on/off - turn on/off atti mode
vps on/off - turn on/off all vison sensors
vled on/off - enable led on/off when record (set led on first)
gps on/off - enable/disable drone gps
CC US/CN/JP/RU/HK… - set drone country code (can disable FCC mode)
droneid on/off - turn on/off droneid (need drone firmware support turn off droneid)
5.8 on/off - enable/disable force 5.8GHz ,disable 2.4G
flog off - delete all drone flight logs (the logs inside drone, logs will be deleted the next time the drone restarts)
landing on/off - enable/disable force landing ( M3 firmware verion <= 900 )
aled on/off - control the auxiliary led ,if you can not control it in djifly
A new feature update has been added to the fcc mod. Use the “photo” command to allow the drone to automatically take photos and set a even one-second time-lapse photography time. Send the command “photo 1” and press the camera button to start taking pictures automatically. The time is one second interval , select a delay time in time-lapse photography, you will see that the time also changes to 1 second, similarly, photo 2 means 2 seconds. “photo 0” for disable. Works in photo mode
Hi
He has also not been responding to me.
Not good customer service at all ![]()
I see him only all the time but probably ignoring is or blocked somehow.
Hi @M3Pro, it looks as though you’re quite new here ![]()
Been told that he is not going to be around for a few months.
But he will be back. Apparently.
