Recommendations for kit
Evening All,
I’m considering landing gear legs/extensions for my Mavic 2 Pro in order to protect the camera when landing on uneven surfaces. Can anyone recommend ones preferably available on amazon?
Also, there has been a few times when ive been out in the field and used my batteries but only been able to charge one in the car when driving between locations. Is there a way to charge the Mavic 2 Battery’s from a Power Bank or is there a portable power bank for the Mavic 2 Battery’s.
Thanks in advance!
Would this work with the DJI Mains Charger with the Battery Dock?
https://www.amazon.co.uk/NOVOO-Portable-20100mAh-External-Smartphones-Grey-black/dp/B07C9S274T/ref=sr_1_3?ie=UTF8&qid=1542750189&sr=8-3&keywords=Battery+Pack+UK+Plug
The mains battery charger is rated as “100-240v - 1.8A” - so whilst this might be a peak power requirement, it does translate into 180W to 430W.
A non-DJI charger is a viable option here mate.
For some reason, DJI require x amount of volts from the car (I forget the exact number) before charing the drone batteries whereas third party chargers don’t have this requirement and operate on a range of voltages :+1:t2:
13-ish.
I must put my voltmeter on it and check the exact value next time.
Thanks,
PingSpike, do you have a link to an example one?
We use a car starter/power bank when out on our travels a reasonably priced option but quite a lump to carry round.
Also charges phones etc from usb ports.
https://www.amazon.co.uk/Sealey-RS1312HV-RoadStart-Emergency-Hi-Vis/dp/B06Y657D1S/ref=sr_1_1?s=automotive&ie=UTF8&qid=1542804019&sr=1-1&keywords=power+pack
I recently saw this on Amazon
https://www.amazon.com/gp/product/B07HVM4R95/ref=ox_sc_saved_title_4?smid=A1BSRCWKIA94M3&psc=1
charge two batteries and remote.
And I use this landing pad religiously - helps with uneven grass - keeps dust out of props … I had landing gr extensions on my mavic and found them a hassle not to mention that I lost one of them in flight once -guess i didn’t get it on secure enough
