Recommended Mini 5 Pro settings for smoother gain, expo, yaw, camera and more
Some recommended Mini 5 Pro settings from @ianinlondon
Covering:
  • Obstacle Avoidance Settings Bypass Mode Brake Mode
  • Optimal vs Preset Return To Home
  • Gain & Expo Screen
  • Max Angular Velocity
  • Yaw Smoothness
  • EXP Sensitivity
  • Max Control Speed Tilt
  • Max Roll Speed
A few pearls there for sure.
Cheers Ian :slight_smile:
I got some footage last night at the Beaconsfield services. Just testing out the low light stuff.
It all looked epic except some occassoonal flickering lights.
I’m about to do another couple of runs with the differing anti flicker settings. Auto/50hz/60hz etc.
Ozonevibe gave me another couple of pointers which go me to shutter stuff. Ill mess with that if the anti flicker stuff doesnt help.
Maybe a nice followup subject for the pro that is ian? :slight_smile:
Hi - Is the low light stuff tangibly improved over that from the mini 4 pro? I’m giving it some serious consideration
Im still looking into it.
The footage of a service station orbit looks epic but i havent done a side by side comparison yet. I am most most impressed with how bright, crisp and vibrant everything looks.
The 4 was damn good to start with.
A couple of thoughts so far are.
The landing led seems brighter or at least visible from greater angles so we can pretend we have proper vlos while flying. :slight_smile:
The obstacle avoidance reports as working forward and down. The little icon shows green for that but red for sides and behind. A nice touch. I guess forward lidar is in play but not sure about downward yet.
I still need to look into the antiflicker situation a bit more. I got footage last night using all the different settings. Ill have a look properly later.
I’m looking into this just to satisfy my own curiousity and to compare my findings with the various talking heads on 'da socials.
I can squirt you a link to the yt footage if you like? It’s just raw footage but mine be of interest.
Thanks - I’d appreciate it - good update too👍
