I was out flying this morning, but when I got home my iPad Mini 5 made like a dead turtle and will not let me sync my flight logs with AirData. Worse, it is now stuck in either a perpetual passcode loop or a reboot loop.
I was wondering if anyone knew if you could retrieve flight logs from the Drone SD Card, or whether they are only stored on the app device?
If I have to reset this thing and restore to factory default I will loose the flight logs stored on the device.
I might be miles out here as I know usually when you delete the app it deletes its data with it so just a guess ok , if you downloaded the app to another device and logged in with your credentials , or bound to the app on another device , no specialist here just a thought ! Hope you get it sorted
Edit : only reason I say this as one of my replacement drones I couldn’t get rid of the credentials last year , so I ended up setting up a new account , can’t remember if it’s stored on the drone too , again only a stab in the dark
