Hi guys.I hope everyone is well. I am writing to you because I was flying the mini 4 Pro last night and the truth is that the image quality is incredible. However, Note that the LED lights only turn on green and not on green and red and at some point they turn off. This is correct, or it is a fault. Thank you in advance if you could explain to me Since when flying at night these LEDs located on the back are of great help. ![]()
I believe that In settings for the Mini 4 Pro you have the option to set the front arm nav lights to on, off, or auto. With auto the front arm nav lights will turn off whenever the camera is active for either video, or stills.
Was you recording video or possibly taking pictures when the ledβs went off ?
The green LED lights will turn off when recording and there is no option to turn them back on till the recording stops and then they will
But you can use the landing light at night
Or you can use Strobe lights, like these
https://greyarro.ws/t/flytron-exclusive-gadc-discount-code/59673
