Ok you did say ANYTHING I’m not sure about just ask! 2 days spent trying to get the remote control to sync with the Mavic Air and after watching HOURS of YouTube still no joy
On the app I can’t get through step 3 it won’t connect RC/MOBILE PHONE (phone I got is a 1+5) to the drone!
I’ve done the press button on drone for 2 secs and 3 buttons on the remote and YES green light…but nothing…the app still says not contacted (stuck in stage 3!), So unpaired them again!
I’ve even uninstalled the app and reinstalled it… still stuck in stage 3!
could I possibly have a duff controller?
I’ve managed to do a test flight using the phone as a remote control (but not comfortable flying that way!)
Thanks for the replies guys, I tried using a different device and it worked fine! So the 1+5 mobile doesn’t like the app obviously! So in going to get a Amazon hd tablet Purley for using when flying the Mavic…can anyone recommend a good all in one holder?
i have found, if controller not connecting to phone via app, …switch controller on connect to phone and then restart phone, dji app should kick in and connect… thats the way i found worked… took me 3 days to suss that out… im using samsung/android…
Thanks for all of that, did try the DJI wire less method no end of times along with the manual system neither worked, will purcahase a new RC to mobile cable just in case, never the less the re up load of the go4 app appears to have worked for the time being needless to say I have lost all of my flight records! Thank you all again.
Am on Android - Go4 have tried the sync, but not producing my records, have flown two batteries this evening all is working well, have also noticed a Stars and Stripes flag in the top panell in the app when the me icon is selected! Thanks for the support.
Have had a look at that but no go, have tried to sync a number of times but can only get the flights that I did after re installing to Go 4 App, as if starting from scratch.
Do DJI keep the logs an a data base, is this detail also held on the drone?
From: “OzoneVibe via Grey Arrows Drone Club UK” forums@greyarro.ws
To: njpelz@btinternet.com
Sent: Tuesday, 27 Aug, 2019 At 20:51
Subject: Remote control not syncing
OzoneVibe 2018 Treasure Hunt Winner - Gold
27 August
There’s folder on the Android device you need to save somewhere safe until everything’s sorted.
It’s the folder …
DJI/DJI.GO.V4/FLIGHTRECORD
… AND the subfolders and all files!
Once you have everything working, you should be able to copy that data back and sync it OK with Go4.
At least the .txt files in that folder can be uploaded to AirData to see the flights.
(AirData is better than the log in the Go4 app, anyway. )
Stormin
27 August
No not coming back on sync, all I have are the flights that I did after re installing the Go4 App, looks like I am starting from scratch!
Are the details held by DJI on a data base that I can request, is the data also held on the Drone, or do I just have to live with it?
Many thanks.
From: “PingSpike via Grey Arrows Drone Club UK” forums@greyarro.ws
Sent: Tuesday, 27 Aug, 2019 At 16:37
Stormin
27 August
Thanks for all of that, did try the DJI wire less method no end of times along with the manual system neither worked, will purcahase a new RC to mobile cable just in case, never the less the re up load of the go4 app appears to have worked for the time being needless to say I have lost all of my fli…
I have used the DJI assist in an attempt to down load my lost flight files from my air craft to my desk top, the records on the air craft only go back as far as the point were I re loaded the Go4 app.
It appears that all previous records are lost, shame rarely as I would have liked to have kept a complete record,I only hope that should I have to send my air craft back to DJI in regard to warranty or the fly more that this problem will not go against me.
I have also been in contact with DJI through out this problem in order that its logged with them and may be they are able to resolve this type of issue in time to come.
Many thanks for your help and in put.
Kind regards
Norman
Sent: Wednesday, 28 Aug, 2019 At 06:55
28 August
There are flight logs on the drone, but those aren’t any use for updating the Go4 log, I’m pretty certain, and definitely not useable for AirData.
Stormin
28 August
Thanks, Have had a look at that but no go, have tried to sync a number of times but can only get the flights that I did after re installing to Go 4 App, as if starting from scratch. Do DJI keep the logs an a data base, is this detail also held on the drone? Cheers From: “OzoneVibe via Grey Arro…
