Is there anyway to remove the audio from a video file? I was videoing some birds with my r7 and someone next to me started to play a youtube vid which my camera picked up surprisingly clearly
Most video editing sofware allow this. Depending on your software once you clip is loaded into the timeline, click on it. Some will gave a right click option to unlink the audio, some will have an option in one of the dropdown menus. You can then click on the audio and dekete it
You can do it in DJI fly app, goto create - pro at top, select your file to edit, once selected there’s volume at the bottom, select that and put it to 0 then save, it’ll then have no audio. Only problem is if it’ll save in the format you recorded in.
thank you both
