Hello all, thanks for making such a helpful website! Have been lurking and reading a lot of old threads. Initially was hit with a lot of legal anxiety but now reassured from much of what I’ve read. I’m based in the North East and we have a lot of nice coast line but it’s almost all covered in a huge red area that extends out to sea on NATS (selected in white on the screenshot).
“name
EGD514 COMBAT AIRSPACE
description
[coordinates]
Upper limit: FL660
Lower limit: FL85
Class: AMC - Manageable.
Activity: High Energy Manoeuvres / Ordnance, Munitions and Explosives (OME) / Electrical/Optical Hazards.
Service: SUAAIS: Scottish Information on 119.875 MHz and London Information on 125.475 MHz.
Contact: Booking: Military Airspace Management Cell – Managed Airspace, Tel: 01489-612495.
SUA Authority: DAATM (HQ Air).”
To my reading this looks like an area that starts with a lower limit of 8500 feet (85 FL), so in any case would not apply to drones, and would be OK to fly (ignoring other considerations etc) without contacting the phone number? Have seen lots of drone footage from here so I’m presuming that’s the case, although it seems to be a fairly new restriction.
What about this smaller area, highlighted below in white?
“name
EGD512B OTTERBURN
description
[coordinates]
Upper limit: 25000 FT MSL
Lower limit: SFC
Vertical Limits: 18,000 FT ALT.
Vertical Limits: OCNL notified to altitudes up to 25,000 FT ALT by NOTAM.
Activity: Ordnance, Munitions and Explosives / Para Dropping / Unmanned Aircraft System (VLOS).
Service: SUAAIS: Scottish Information on 119.875 MHz.
Contact: Pre-flight information / Booking: Range Control, Tel: 01912-394261.
Remarks: SI 1971/919 and SI 1980/38.
SUA Authority: DAATM (DIO).”
This extends from the surface so would seem to apply to drones but I’m not exactly clear what it is or what it practically means. Otterburn is a military base so I would expect not to be able to fly around there but the zone extends quite far from that and covers a lot of areas of natural beauty. Other than presumably an area where the military may be doing various dangerous things, does this mean that if you are planning to fly anywhere in the area you need to contact the number first?
Thanks in advance and sorry if it’s a stupid question!
If it helps, I have done this for a similar area in Wales, and the guys on the end of the phone were friendly and helpful.
I think they respect the fact that you are trying to follow the rules, and are trying to keep everyone safe
Hi @thisismycatch22
Otterburn ranges are extensively used (or certainly used to be) by the military for infantry/paratraining (from helicopters ).
Even if you got permission then I would be very wary about flying there without extensive lines of sight due to the above.
I’m not saying don’t fly, but just be aware due to the above.
Rob
In addition to the above advice, check first the height restrictions for the training area that effects you. In my case (North Sea ) it is only above 15,000.
P.
Thanks, yes I did think the area might just correspond with the Otterburn ranges and so was going to avoid those for sure but particularly on the south it extends a bit beyond what I would have thought of as the ranges on the ground. Will just avoid the whole area to be safe. Would be nice to film around Hindhope Linn though, I guess if I get bored one day I will ring them up and find out what the situation is!
Thanks all others for helpful replies as well
It is looking like the Military Airspace is being used for training. I would check with the Managed Airspace control and see what the situation is. Military Aircraft can get really low and can come as far down as they need to when practising. I would personally always ring them just to make sure and just to inform them that you are in the area
So with it having a Lower limit or 8500ft if they then come low enough to collide with a drone surely they have broke the rules? Coming as low as they need isn’t really viable!
The rules of the “air space” they have designated (fl85) 8500ft lower limit!!! If they come lover than the provided information how can someone else be liable for that
No. Those are the limits of the air space, not “rules”.
The NOTAM only specifies the dimensions/location of an air space, and what to expect to be happening in it or, when specified, what mustn’t go into it.
That’s where they are expected to be performing their assigned tasks.
Nothing in the NOTAM forbids participating aircraft from being below/outside that space.
Just at well .. it would make landing really difficult.
Called the number and had a conversation with a guy from there end, Basically aircraft is not expected to come lower than 8500ft he couldn’t give a definite yes or no as to drone use (possibly so he can’t be liable) But he did say with the drones legal max altitude of 120m there should be no issues and there was nothing on there system saying drone use prohibited.
