Just to the left of the Pin is an ideal place for parking (free), allowing easy access to the river. There is a towpath that (going North) takes you to the Bann roadbridge (a reasonably photogenic bridge, esp' at night, see 2nd photo below)
The towpath is used regularly for dog walking and cycling, and anglers regularly fish from the banks of the river. TOAL can be from the stoned carpark (if you take off from your car roof) or from the towpath or any of the many anglers points (not sure what they are called, little jutting-out-into-the-river bits)
The Rowing Club holds an annual tournaments which usually draws a crowd.
There are 30+meter tall trees between the carpark and the river, so make sure you set your RTH height high enough if you take off from the carpark.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 03/03/2022. It remains the responsibility of any pilot to check for any changes before flying at the same location.
