Since I upgraded to crossfire Iv found I have a real black spot if I fly round the back of me. Never got this issue with vista?, its so bad Iv had a quad drop out of the sky
What power are you running your tango2/rx at?
Is there anyway of boosting the signal from me Tango2 ???
- Press and hold the menu button
- Click the jog wheel on tbs agent lite
- Click the jog wheel on tango 2 XF
- Click the jog wheel on radio settings
- Make sure you’re set to 868MHz
- Set max power to what ever output power you want to run at. (but to keep things legal it should be set to 25mw)
There seems to be a typo on my radio though as theres a 0 after the 25
So I’ve logged a ticket with TBS support. ![]()
Pmsl cheers mate ![]()
turn on ‘Dynamic Power’ ![]()
Yeah, good shout @Steviegeek I use dynamic power too ![]()
How far away were you when you had the failsafe?
Not far 30 feet or so ![]()
In Betaflight???
No, on your Tango 2. will be in the same place as your output power. under radio settings.
