re. TS100
I bought one of these for portable work but find myself using it more and more on the bench
I’ve got three sizes of tips and it does everything from 0603 SMD’s to XT90’s
Steve
Beat iron I have ever used. You can also play pong on it
Is the TS100 battery powered?
I’ve got a Weller WD1 which needs a new iron and a gascat 80 which is playing up.
Loathed to spend £100 on the Weller iron and gas irons were great in the past but think they’ve had there day.
Can’t beat the Wellers, to bloody expensive these days though !.
Had my Workstation for 30 years, past it’s best now though.
I swore by my Weller Pyropen. Worked great for soldering RF cables while hanging 60ft above the signal deck onboard the ship.
Nidge.
It will run off a 4s lipo or a mains psu (I use a toshiba laptop power brick at home)
Thanks mate ![]()
Think I’ll order one.
Hi,
I feel I should add to my previous post (#41) regarding the use of this TS100 iron.
It’s rated 12v to 24v so it suits a 3S (11.1) Li-Po pack.
However the power rating (i.e. it’s capacity to push out a lot of heat to a large joint) is dependent on it’s supply voltage.
I run mine from a 5S (20.5v when charged) Li-Ion 18650 self-built pack.
I reckon that to do the big stuff like 10awg cable onto a XT90 needs to have at least 19v (40W) and the large tip (TS-C4)
Another thing to bear in mind is that depending on the stock firmware that you get with your purchase, you may find the ‘time to sleep’ is very short and that can be a real pain.
Consider updating the firmware to one of the open-source offerings (I run the Ralim Tek APPV218)
here’s some useful links…
http://www.minidso.com/forum.php?mod=attachment&aid=NzAwOHw1NjAyNjE2ZnwxNTgyNTUzNDczfDB8ODky
http://www.minidso.com/forum.php?mod=viewthread&tid=892
Cheers, and enjoy.
Steve
Jeez Steve… I need to update the firmware on my damn soldering iron?? I think I’ll just stick a fork in the fire…
Not essential it works fine out of the box.
Just might make life easier for you
Anyway don’t us modellers love tinkering
Steve
Zoefpv unicorn build (some mods still to be completed)
Armattan badger dji editition with fettec stack and tmotors
Hoping to have at least one of them done by the weekend
Wiil look forward to seeing them out in the skies
Steve
PS, your workbench is a damn sight tidier than mine !!!
My work bench is the kitchen table
What’s the frame with the yellow plates? Looks nice. Is one of them for 3d flying?
The one with the 3D printed mounts is the zoefpv unicorn frame. Aimed squarely at 3D flight. It’s been a love hate relationship with that frame from day 1
Why’s that? Can’t wait to see you fly it. Should be fun!
Well it’s designed for a 30x30 or 20x20 stack based on m3 bolts…
I needed to shoehorn dji stuff into it…
So that means 20x20
Most 20x20 use m2 bolts… So that was the first problem followed by trying to fit the vista in (originally planned to use an air unit but just wouldn’t fit).
So with the help of @evilbobbins we got a design to mount the 2 20x20 stacks
Only the frame doesn’t want to go together with the stacks mounted so yea it’s a pain in the ass.
When I break the frame (and I will) I won’t be replacing it with the same frame
What would you say is better, vista or the stock air unit? Or you not tried it yet.
