The event will start just after 10:00 when the Moon will begin to pass between the Sun and the Earth.
It will peak nearly an hour later, between 10:50 and 11:00, and end about 11:45 - although times will vary slightly depending on where in the UK you are.
My brain even remembered to change all the rather extreme settings back to normal - before I grabbed the camera in coming days and wonder why everything came out black.
