Some advice on new printer options
I’ll try and keep it simple. I’m looking for a printer under £200. Don’t need multiple colours (yet)
At the moment I am looking at Ender V3 SE. Is there anything better out there I should consider? Not interested in wifi or plugging into pc, I’m fine with sd cards. I’m after something that just works and gives decent prints in a reasonable time,
EDIT
I will also consider used/second hand models if it gets me more bang for the buck
The Ender V3 SE is a reasonable entry level printer with a 220 x 220 x 250 build volume that can handle PLA, PETG and TPU. If you think you may want to print using ABS or ASA filaments then you will need to consider an enclosed printer. The auto levelling on the V3 SE will make things a lot easier. As I remember what a pain it was to manually level the build plate on my first printer which was an Ender 3. Another thing to consider (a bit like drones ) is how long before you reach the limitations of the printer and decide you need to upgrade.
I spent 4 hours tearing apart a borrowed ender 3 pro yesterday, rebuilding it square and parallel, setting the eccentric rollers, re-tensioning belts
Eventually got the bed level and printed my first successful benchy! I was thinking of getting the same model second hand, but would love to have auto levelling!
Piccie?
Don’t be too harsh, this with default print settings
Any Benchy is a good benchy, these things never cease to amaze me
I remember watching in awe my first dot matrix printer, then ink/bubble jets. Laser was just magic.
Then the first time I saw a 3D printer it took up half a room and days to print even the simplest of thing
WTF - how old are you?:flushed_face:
I suppose you recall the hammer & chisel too. :rofl:
Same here!
यभ
This will do it
https://www.ebay.co.uk/itm/407132726554?var=0&shprz=EBAY_GB_58058&_ul=GB&toolid=20006&mkrid=710-53481-19255-0&campid=5338986375&loc_interest_ms=&loc_physical_ms=9045594&adtype=pla&customid=CjwKCAjwiL7VBhA-EiwAhZi9EOOW1KMospOFKUSG7vqQXWNUHBC3ABHrQ-oP0fp-gwYEcaznuiuUUBoC3-AQAvD_BwE|null|null
On this
yep, I bought my paper through work from Viking Direct.
:rofl: bought :rofl:
That’s why I took a rucksack to work every month
the 3 pro does the job, but the V3 SE will also speed things up a bit
