St Aldhelm's Chapel is a Norman chapel on St Aldhelm's Head just beyond the village of Worth Matravers, Swanage, Dorset.
It stands close to the cliffs, 350 feet above sea level and is a Grade I listed building.
The square stone chapel stands within a low circular earthwork, which may be the remains of a pre-Conquest Christian enclosure.
The building has several architectural features which are unusual for a chapel, most noticeably from the outside its square shape.
That whole stretch of Dorset’s Jurassic coastline is great drone flying land/seascape, but borders the Portland and Lulworth airspace restriction zones so care needs to be exercised if these are in effect (both are normally just Mon-Fri but check before flying).
This location is NOT in either of these FRZ’s
Parking is 1.5 miles away so good walk-in is required to get to the TOAL point which is from a public footpath close to the chapel
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 09/06/2025. It remains the responsibility of any pilot to check for any changes before flying at the same location. Landowner permission may be required before taking off.
