Successful Lightning Triggering and Guiding Using a Drone
Wow! If I understood the article, the drone is connected to the ground by an earthing cable, but free-flying and not tethered in any way, so it isn’t quite the same as Benjamin Franklin’s experiment with a kite.
Faraday cage around the drone or not, I’m not going to try it with my Mini 2 just the same, thank you… The cage would put it over 250g anyway!
