Tablet Questions
Evening Guys!
I know this has been asked several times! But looking for some insight!
I currently use my Mavic 2 Pro with my Iphone XS MAX.
However, im considering getting a tablet.
Now, i swear by Apple however i cant justify the cost of a Mini 4 just to use with my Mavic.
Any resonable options for a second hand tablet that would suit? i looked at the Nvidia K1, but there hard to come by.
Not looking to spend much. up to £100. £150 at a push.
Thanks!
When I bought my Mavic Pro it came with RE goggles and a Huawei MediaPad T3, it had very little use and the person I bought it from swore by this.
I have never used it as I have a iPad Pro so can’t really comment.
Argos and Amazon are selling these for under £70.HTH.
https://www.argos.co.uk/product/7193673
https://www.amazon.co.uk/dp/B073VX18JT?tag=amz-mkt-chr-uk-21&ascsubtag=1ba00-01000-a0049-win10-other-nomod-uk000-pcomp-feature-pcomp-wm-3-wm-8-wm-4-wm-1&ref=aa_pcomp_exp4
Pretty sure the T3 only works with older versions of Go4.
Could be a problem if newer features were needed.
Ill try and find the discussion.
T3 is great but you may find it a touch underpowered.
I used iPad 2 mini but could not view on bright days, bought a nexus 7 2013 from fleabay for £30 and hardly ever needed the cumbersome hood did not drop signal and easily hackable to run nice apps plus 2gb ram which is great.
This is curious. I was trying to get my Nexus 7 2013 working with the DJO Fly app but it was having none of it. Turns out you have to be using a 64bit ARM processor for the Fly app or it just isn’t going to work.
Original question here was around the M2P which uses DJIGO :wink:
t3 works perfectly for me. I don’t have a newer drone so use the older version of dji go. I just installed the latest version and it works fine, obviously I cannot test it due to not having a current drone.
I used it with Mavic Pro!! plus modded NLD DJI GO App.
