Looking at those layouts, I’m thinking that doing an entire row at a time might be an easier route …
Pan right down. Take 1.
Up 30deg.Take 1 every 60deg. (x6)
Up 30deg. Take 1 every 40deg. (x9)
Up 30deg. Right 20deg. Take 1 every 40deg. (x9)
… gives you the 34pics as per the Mavic.
Just a silly thought … that I may try some time.
Of course, it doesn’t put them in nice folders, so you need to keep track somehow.
If it’s any help, when I used to use Hangar360 it’d do the second method… it’s set the camera angle then rotate around 360 degrees collecting all the photos at that angle, then it’d drop the angle of the camera and perform another 360 spin.
Probably far easier to do it this way manually.
Just set a good reference point I guess?
Or use the map view on the GO4 app, as this also shows the orientation of your bird too
Got a lot on at the moment to squeeze out of a pension that’s not what it was supposed to be. Have to justify spending. (Says the man with a Mavic! LOL)
Just want to tweak some settings … because of where I live.
Otherwise, more than happy with it as it is.
Not made up my mind yet. Exploring how to best get around the loss of pano.
As for Litchi … see above post. Can’t justify £ atm.
Totally manual capture.
25 images.
1 straight down.
8 each at 45/0/-30
Manual exposure
I switched Go4 to map mode to guess the panning angles … starting off pointing due North.
After each set, I obviously had to switch to FPV mode to adjust the camera pitch.
Another time, I will try better vertical overlap by doing the one straight down (90), then 8 at each of 50/10-30.
Overall I’m really pleased with the first attempt.
Downside? It’s slow to do.
Incidentally, I used a shot 90deg to the sun, with 25% sky / 75% ground to base the manual exposure.
Litchi could have worked … but for my use I’m not sure it’s worth the £££. This is more to determine if there are ways to get a better result.
I should have taken a Go4 pano in the same location … to compare results.
It didn’t take too long - 3 minutes for all 25 pics. Not bad for a first attempt.
Even the Go4 360 takes a few seconds over 1 minute!
If you click on the full-screen button, then take the link to Kuula, then take the full-screen from that, then zoom in to the river … you can see loads of great reflections!
