The Great Big - DJI Flight Simulator Thread
Hi,
Is there a Windows flight simulator for the MM?
I looked at DJI assistant 2, and it looks like there’s something there but talked about taking the props off?? :thinking:
Is there anything that would let me plug my controller into a laptop to do a simulated flight?
TIA
Ned
After some investigation, it does not appear that there is.
I had some limited success with the DJI Simulation software by selecting a Mavic Air and using the MM controller… But it wasn’t great TBH.
Ned
Does anybody know of any free/cheap/small sims?
Simon
@eastsuffolkdrone have moved your post here as this is probably what you need.
Thanks, @Committee!
Has anyone tried the simulator with the mini 2 control.
Do you get a free 30 day trial.
As a newbie it could be handy to use as the weather ain’t brilliant
The mavic 2 pro / zoom controller works.
3 posts were split to a new topic: Temp
Guys
Has anyone purchased the full version of this seems a bit pricey
Ian
I was thinking of it while on lockdown tbh but haven’t looked at prices yet
Sut down before you do @Matty1😱
Hi has anyone used the DJI Fly simulator with the mini 2 as I believe the control can connect to this simulator and I believe you get a free 30 day trial
could be useful to learn how to fly a drone while the weather is not that brilliant. Especially for a newbie like me :smile:
MM2 doesn’t appear to be a supported device.
https://forum.dji.com/thread-228883-1-1.html
MINI 2 controller doesnt work can confirm from DJI AS i asked them the other day on twitter :slight_smile:
Thanks guys.
Weird because the Mini 1 controller did.
But the Air 2 doesn’t.
Same controller as the above.
I read on another forum they have no intention of writing it in either, wether I believe that or not
Hi everyone. has anyone use the DJI Flight simulator on a PC and has connected and found the right settings for the Mavic pro controller? Not the Mavic 2 pro controller even though they look the same but when I am in free flight mode it tells you to press shift top left side to toggle between screens and mine does nothing. the controller I used was the Mavic 2 controller as it does not show mine but you can select my Drone. Very strange or am i looking at this wrong. Could anyone advise please?
thanks Shaun.
Lol I’ve experienced this using my M2P controller, if you press C on your keyboard it’ll change views to FPV
Moved your post to a thread where this is already discussed.
