The Severn Bridge - Added to Bridges in South West
Parking: 51.604840, -2.621987
TOAL: 51.605348, -2.626906
The closest place to park to the viewing point is in the Travelodge carpark. Then walk through the now closed Brightside Insurance car park. It takes about 5 minutes.
The Severn Bridge cost £8m to construct and was opened by Queen Elizabeth II on 8 September 1966. It replaced the vehicle ferry between Aust Cliff and Beachley Peninsula and carried the M4 motorway between England and Wales. The main section spans the Severn Estuary. The road continues on a smaller section across the river Wye and, a little further west, over the Wales Coast Path.
Two concrete piers, 988 metres apart, were built up from the bed of the estuary. The Aust pier rests on a limestone outcrop while the Beachley pier rests on hard mudstone. The bridge’s towers were made of high-tensile steel, weighing 2,700 tons in total. From these towers hang the suspension cables which hold up the deck.
An innovative form was developed for the deck to streamline it against the strong winds which sweep along the estuary. The edge of the deck on each side is like a blade, and the wind is smoothly directed over or under the deck. Without this aerodynamic design, the bridge deck would have been much heavier to withstand the wind pressures, which in turn would have required bigger and more expensive support structures.
The high winds caused many accidents, and the bridge was often closed during gales. Congestion began to occur at peak travel times, as traffic using the bridge increased by 63% from 1980 to 1990. In October 1990 a contract was signed for construction downstream of the Second Severn Crossing, to deal with growing traffic and provide a less wind-prone route over the estuary.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 05/02/2023. It remains the responsibility of any pilot to check for any changes before flying at the same location.
Ahh yes - forgot about that one. Should have added it a few years back. LOL
I should add - whenever I go I park down by the site of the old Aust ferry, and on a good tide day you can even walk out across its remains but be sure to time it correctly as the Severn has the 2nd fastest (I seem to recall) tidal rate.
Here’s a pin for it for those interested: Google Maps
I can see it, good tip. If you don’t hear from me again, you know I messed up the timings :wink:
I’ve flown here too @clinkadink :grin:
