This is probably a silly question, but I want to check my understanding of how the software “sits” on our physical radios.
We have a module (I have 2, 1 internal, and 1 plugin), and they both have their own firmware which you can update…
Then the radio has an SD Card, and I assume a flashable bit for the radio firmware (Edge TX V2.x… or whatever).
The SD Card I guess contains the models, scripts, sounds, etc and the flashable bit is the OS/Software for the version of edge TX?
Are these assumptions all correct? I believe I’m at a pain point of where the Edge TX devs changed the way models are stored at some point, and I may just wipe the whole thing, update everything (internal module keeps moaning for example) and then slowly add models as and when I’m going to use them again and setup all the screens the same, have proper photos, etc…
BTW I’m running a TX16S with EdgeTX 2.6.0 from January, and had bought a better 64GB card months ago it’s about time made it into the radio (still on whatever original SD Card I was provided back in… whenever I bought the thing)
