As I slowly raise the throttle (no other inputs) it reaches a point where it just yaws and cuts out.
If I slowly apply some roll (before take-off), it will start rolling in the correct direction and then start rapidly rocking from side to side until it cuts out.
Clearly something is wrong and instinct tells me it’s to do with orientation sensing somehow.
This all flew perfectly when it was in the 3D printed Nano Long Range. Differences (aside from the new frame) are:
It is now powered by a 2S LiPo, so no 5V uplift required
The FC has been flipped - it was technically upside-down in the Nano
I have checked
The depiction of the quad moves correctly in BF\Setup, so I assume I have re-calibrated the gyro correctly
The motor order is correct
The motor directions are correct
The props are on the right way around (verified in BF\Motors - if I give a single motor some juice the correct corner starts to lift)
Controls respond correctly in BF\Receiver
Currently stumped, but I really need to get back to work.
You running 4.3? I’ve found strange and flyaway behaviour and have to find tunes (from presets) for quads of different sizes. If the Gyro/Accelerometer are reacting correctly (you checked accelerometer, did you check gyro?) in BF then it could be that rotation is wrong?
But you are running double the voltage which will have an effect I’m pretty sure! My guess is that’s the issue. I’m not expert on tuning though, which is a pain!
That’s the badger! I was so convinced that the board was upside-down in the previous build but I didn’t’ twig that I hadn’t had to mess with these settings before, so they would need doing now.
We’re up and terrorizing the cat.
It would be nice if I could get the WiFi working for SpeedyBee but although the phone will connect to it, SpeedyBee doesn’t see the device and then seconds later the WiFi seems to disconnect itself. Oh well, something else to dick with later.
Ah my bad I thought you had a Speedybee fc
Have you got the latest version of the Speedybee App? Also have you got your location settings turned on? For some reason mine wont connect unless location is active
Honestly, now it’s working I care less about getting WiFi connectivity. The USB connector’s an arse to get to so I was getting fed up with it.
Had a quick bez around the park across the road just to make sure. Unfortunately I’d forgotten to charge my goggles so I only managed 5 min and the video I took was corrupted. D’oh!
