Has anyone seen or tried these tiny GPS modules?
They’re quite a bit smaller than the usual ones and have an antenna that could be placed out of the way somewhere.
Might be good for those smaller builds.
No, not seen these before.
Seperate aerial could be good ![]()
somebody will have to buy some and report back… FPV review page ?
I was just about to… then thought I better check if someone had done so before!
Oh, a search found this rather inconclusive page:
So it arrived… It’s nice and small as shown in the photos. I have the ATGM336H version.
I followed the guide above and set it to 10Hz and Baud Rate of 115200 using one of these…
Connected up to a spare Uart on my Tadpole HD. Changed the Baud rate to match above and set the protocol to NMEA.
It is now sat on my windowsill happily picking up satellites!
It works!
Ooohh. Very cheap and small. Which one is it you got? I have the serial to USB adaptor, so can program it… The ATGM336H with the antenna?
Yes thats the one.
Will have a play with these tonight. Easy enough with the guide above @Yith ?
Yeah, not bad at all.
