Tripltek 8 pro for sale - Price reduced to £450 - [SOLD]
Excellent condition.
Original box included.
Brightest tablet available, perfect for drones in direct sunlight.
TRIPLTEK Ultra Bright 1200 nits Display
The Ultra-High Resolution 8 inch Display of 1200 cd/m² Sustained brightness makes the TRIPLTEK the brightest tablet/smartphone on the market, more than three times as bright as a typical mobile device. Operate your display under direct sunlight and all-weather conditions thanks to the glove touch and wet touch features.
Fast, Reliable and Long Lasting Battery life
Equipped with extended use in mind. Keep your device fully operational through a battery that holds its charge for up to 30 days on standby.
Get back to work faster via fast-charging technology.
Compatible with All Drones
Best in class drone companion. Built to work as a drone operating device, with compatibility in mind. Operates all commercially available drones.
Always Connected 4G LTE, GPS, WIFI, NFC LTE, GPS, WIFI, NFC
4G LTE Smartphone , WIFI Dual-brand (2.4GHz/5Ghz), GPS and NFC
Connect to your devices and stay linked with a steady transfer. Get accurate and real-time positioning information on the move. And use Google Pay thanks to the NFC connectivity
Protected Against the Elements
Built using high strength polyurethane and aluminum alloy. The TRIPLTEK is protected from accidental drops and is able to support up to a ton of pressure, it is also dust and water-resistant IP-68 and can withstand extreme temperature ranges ranging from 0°F to 120°F.
Cost over £900
Looking for 650
Collection preferred from Warrington WA2, but can post at buyers cost/risk.
Reduced price to £450
Down to £300.
Its just sitting in its box waiting for someone to grab a bargain.
There is a tripltek RC mount with it too.
