interesting, I read the act, well most of it, skimmed.
I then back tracked to to to establish what exemptions there are for requesting or requiring a broadcasting licence, given the act “basically” says if you (or an apparatus) you intend to operate, it needs a license UNLESS it’s given a specific exemption from ofcom. (section 8)
after I established that I went searching for the specific exemption devices, … given otherwise you would need a licence for every wireless device you own (mobile phone, WiFi routers, wireless thermostats, cordless phones etc etc… wireless light switches and plugs etc etc )
I came across this bit of guidance relating to exemptions and “radio controlled models”
I then delved down into the actual exemption guidance document and it seems that “models” are covered under
ir2030/23 relates to model control
scrolling down to pdf page 89 (page number 87) covers the transmission frequency and powers that are permitted for licence exemption for “model control”
I’m not seeing the 2.4ghz or 5ghz frequency range…!
which probably means that all devices that use those frequency ranges for “model control” should have or need a licence to permit their transmission
the exemption list is very specific you cannot mix and match applications… so saying you are using a WiFi frequency for model control is not acceptable under the ofcom exemptions…
this will be a very interesting one if ofcom really are going to TRY to prosecute someone as technically they should not be broadcasting on any frequency for model control other than those listed, never mind the FCC power bands…
I can’t see them winning. (given the devices should not have been offered for widespread sale and advertising in the UK)… but really only the lawyers get rich of these things
popcorn
the outcome will probably be ofcom needing to update their model control frequency bands and adding the appropriate power ratings which are acceptable…
I did hear a rumour that ofcom were looking to expand the power ratings for WiFi devices to align with the FCC, given there were too many devices on the market
the following cover WiFi I believe… although it’s probably worth noting that the power bands are higher and they exclude airborne model use!
IR2030/8 Wireless Access Systems (WAS) Equipment, including Radio Local Area Networks, designed
for highspeed data communication.
IR2030/9 Short Range Indoor Data Links Equipment designed for data communication for indoor use.
a good lawyer will avoid any issues I suspect as it’s a bit unenforceable as the exemption list looks out of date
