So i use airdata to record flights with my Air2 & FPV. Usually it is connected to the DJIFLY app. However tyhe past 6 flights i have not needed to connnect my FPV to the app. How can i upload the flights to Airdata? I can not find the “flight record” on the sd card either goggles or qwad.
That’s why then Can’t use the app anymore either as I did the FCC hack to improve signal. If I plug in to the app I lose the hack. Signal is better than recording a flight and upping my hours badge
They store in the goggles until you sync them with DJIFLY by plugging your phone in, it’s a bit of a phaff, especially as we all seem to be using the FCC hack so avoid that shit
If you use the `drone-tweaks app, you can have all your drones which are on the fly app, on fcc. Also you can upload all your flight logs with out losing the fcc hack.
Can you not just copy the log files from somewhere and upload them manually?
Albeit on my MP, not the DJI FPV, I’ve never used the app to upload. (Mainly because that way I know I have a permanent copy of the logs myself, locally.)
But they must exist somewhere to be copied.
I know the AirData site gives instructions for where to find them for most DJI drones - so probably the FPV drone too?
