My concern (slight hesitation) is getting the drone down the other side, ensuring nothing gets tangled. Is that nothing to worry about, as long as there’s enough slack?
My first thought too. But a fishing drone technique might work.
They are used to carry a line from a rod and reel several hundred metres out to sea. My understanding is the line is weighted and it is suspended from the bottom of the drone by an almost horizontal piece of wire, pointing slightly upwards. When the grop zone is reached the pilot hovers and yaws the drone 180 degrees the flies further out to sea. The line drops off.
I think nylon fishing line would be more manageable than dental floss - but I will provide the (constructive?) criticism, you can do the practical tests
@macspite Fishing drone style looks like it could work well, thanks.
Getting some fishing line is a better idea. I have dental floss already, which is where the idea was from. A 50m spool is about £1 and just a couple of grams!
Since Tim @timxjr1300 got his drone stuck up a tree, I always keep 30m of nylon rope connected to a lead weight in my kit bag. Cheap as chips but very effective.
Hi all
Silly question ( as usual ) why do you guys carry the nylon string / weight ? Am I right in saying if it gets stuck up a tree ? Do you have to try and lasso it down as such ? Sorry for the question never heard of this before so just curious !
To retrieve drones from trees. It’s not 100% effective, as it depends on the tree and how accessible it is.
You hold the rope spindle in one hand, feed out about 4 feet, spin it with your other hand, and let go (whilst still holding onto the spindle). The weight carries it vertically up the tree, and the aim is to snag a branch, shake it, releasing your drone. You then pull the rope/weight down once the drone is down. Kind of like a cross between Bolas and Rope Dart.
I know of one person who tied string to his drone in an attempt snag another drone in a tree and hopefully pull it free. The string below his drone got caught up in the tree, his drone continued to pull as much as it could, and the string attached to his drone pulled a leg of the drone to the folded and closed position. That was it for his drone - down it came. Thankfully it didn’t remain snagged in the tree, otherwise the score would be 2 zero in favour of the tree. I guess the lesson is, don’t attach the string to any part of the prop arms.
