Recorded a flight today, or at least I thought I did but there was nothing on the SD. There seemed to be some and a few photos but I think that’s what was cached as opposed to saved on the SD.
I did forget to format the SD could this be the reason?
Also when you do a recording is there anything I should to to ensure it saves to the SD as opposed to caching it.
On your SD card when you view it on a Mac/PC you will see two folders, one of these is the low res cached files. You can clear these by formatting or doing a video cache clear on the Go4 app.
When I viewed it on the PC, would even open it said something like format not recognised…
So put it back in the MP, and what I could veiw is what I think was cached. I then formatted the SD in MP, then put it back in the PC which then let me open a folder on the SD, obviously empty though.
Which makes me think It was because I didn’t format the SD?
Yes formatting does seam to be the issue here. I pull off the media I want on the Mac then put the card back into the Mavic then format. Trouble free so far.
If you are recording while flying, then you land your drone and turn it off without stopping the recording, your file on the SD card come corrupted and you can not view it on your sd card. But you can view it on the app from the cache
