Viewing 3D drone pics
I like to create 3D images of my drone scenes, and when the opportunity arose to get a proper stereoscope, I acquired it:
It works well, with a bar of LEDs along the back to illuminate the prints.
To view in stereo, the prints must be oriented in registration with each other, and held in place while they are moved around under the stereoscope. The prints are held in position with magnets on a 3D printer build plate (Bambu H2S) which, being flat and magnetic is perfect for the task. The build plate needs to be moved in two directions (up/down and left/right) without being rotated, which would destroy the 3D effect.
Thingiverse came to the rescue with several designs for X-Y tables or compound tables. However the easiest device turned out to be an artist’s easel , minus some of its fittings:
I printed off some shims (Tinkercadded) and added some elastic to hold the build plate in place.
The plate is held at the sides, and can be moved left to right along the track. The Y axis is achieved by sliding the plate between the jaws:
The rig works well and allows me to roam around the images I take with my drone in 3D ( a stereo pair of Breedon quarry)
