After last weekends treasure hunt, I wanted to fit my ViFly finder 2 to my TurboBee 160.
After watching videos and reading the instructions I note that the output suggested in the instructions are already being used on what seems to be a very small board.
Can I use any alternative contacts or should I solder to the ones already in use but suggested by the instructions?
I will say that the B is currently taken as is every other possible contact on that board. So do I solder two wires to the Bz contact or remove what’s there and solder to the bz and other available ground and 5v on the top board?
Without seeing the board its impossible to say. If something is already attached to the BZ pad then I’d guess they’ve re mapped the resource to a different function.
Depends if its 5v out or not most VTXs have a 5v out for powering a camera directly from the VTX that will work fine. You’ll need to find the wiring guide for the VTX though to make sure or test it with a multimeter
Well a big thanks mate as I did what you said and it worked treat, it took 1 pair of glasses and a very strong magnifying glass…
Just one more Q is super glue safe to use on my board as the transistor is lifting on the side iv soldered. Hence I was going to fix it in place with some glue …
