Nicely done.
Do they still stand the dead up at bus stops in Weston to make it look busy?
This adds the Coastal Flyer Badge to your profile!
Nice and slow and a lovely edit Shane
Pretty much lol .
Thanks .
All my settings were wrong and took ages to render in FCPX .
Live and learn as they say n.
How can i get rid of the flickering .
You can notice it when i pan along the pier legs ?
You’ve rendered in 30fps … was it actually recorded in 30fps?
Yes 30fps . It was shot in 4k and also render down to 1080p
Which 4k setting? 4096x2160 or 3840x2160?
First one
Ok . What should my settings be .
Thanks for the help .
If you want 4k @ 30fps, use 30fps option on the other one
I would prefer to film in 2.7k as less rendering time .
I seem to recall you have the 60fps rate option @ 2.7k, too.
Will give that a go on the next flight .
Thanks for the advice ,
Would this be a good option ?
I just checked - only 24/30fps @ 2.7k
30fps @ 2.7k is what I use most of the time.
I will go with that in future . .
Thanks .
I have been flying a few years with the Advanced and never had the flicker issue at all .
Just a learning curve and help like yours .
